The Ebyte module, figuring out from Google results as I can’t find a direct match, is one of their module to module only items - they do not do LoRaWAN.
You’ll see on the product page http://www.ebyte.com/en/product-view-news.aspx?id=223 that it does indeed use LoRa and it uses the same chips that LoRaWAN modules use, but it does not have any facilities built in for LoRaWAN
The Dragino OLG02 is a dual channel system which does not support the full 8 channels that LoRaWAN devices will expect, so when they transmit there is a good chance they won’t be heard. It also disrupts the other TTN devices that are in radio range of this system and they will loose data too.
Also note that since these devices are in effect an SX1276 with a non-linear power amplifier added this means there is limited control of output power. Thus you may not be able to reduce the power to legal limits.
thanks for your reply,
Now the new question is if it would be possible to have results with another protocol different from loraWAN, since both are SPI?
I’m new to Dragino water leak sensor. Is there a way for me to read the leak detector transmission with a regular Lilygo Lora ESP32 board? I just need to read the information without a Lorawan.
Technically this might be possible by using the same frequency, SF…
But this forum is dealing with LoRaWAN and TTS, if you don’t want to connect your sensor to TTS your question is offtopic for this forum.
Rather than use the Dragino sensor which you may get to work on a single channel using AT commands, I suggest you use an Arduino with a LORA shield and connect a water level sensor. It will happily pass data to a second Arduino/LORA several hundred metres away. I’ve done it and it works well.
Hey there, I recently purchased “Waveshare SX1262 LoRa HAT for Raspberry Pi 868MHz Frequency Band”. I have the Dragino DLOS8N Gateway. Can I send data to the gateway using this LoRa Hat and Raspberry Pi? Can anyone please suggest possible ways to use this board?
Thanks In Advance
Thanks for your reply @Jeff-UK.
So, I can’t send data to the gateway using these modules mounted on Raspberry Pi 4? By using Pico, I can send data to the gateway! What could be the possible reasons? And are there any other modules available to use as nodes mounted on Raspberry Pi to send data to the gateway?
Not looked in details but think the Pi versions are LoRa only……you need to run a LoRaWAN stack - with somewhat deterministic/hard real-time behaviour hence need an embedded MCU for that rather than the general purpose/Linux base of the PI, but no doubt someone will correct me (not a Softie!). The PiCo of course is based on the RP2040 embedded mcu and I believe there are now LoRaWAN stack ports from various sources which therefore enables a LoRaWAN and not ‘just’ a LoRa node.
There are a number of Pi HATS in the market……these tend to be based on LoRaWAN modules ……running their own internal stacks on separate mcu inside, that typically communicate with Pi over UART/serial and often have +at like commands. (GIYF)
Please do not share pictures that we can see online. Or at least, ensure we can read the writing on the important bits - zoomed in and left to right - volunteers don’t have time to download, rotate & zoom and it’s a multiplicative effort - you do it once or it ends up being down half a dozen times by other people - this does actually contribute to global warming.
But also, why post them at all when you already know that they don’t work with LoRaWAN?
You’ve already been told this. And it says on the vendors website.
Where did you get that idea from? If the Pi can’t send LW, why should the Pico, a much smaller & less capable MCU be able to send? And how do you intend to wire it up?
As @Jeff-UK suggests, a LoRaWAN stack on a Pi is tricky, which is why you don’t see much of it around. And to that end, you’ve been told that that HAT isn’t going to work with LW.
Please start a new topic telling us:
What you want to achieve - not the full details, just an overview
What you are familiar with - Pi, Arduino, ESP32, radio systems, programming languages, soldering skills etc
What resources you have you’d like to use
And provide some indication of prior research in terms of ensuring you have read the Learn section on this website and that any particular products that you can get locally.
And then we can make recommendations of what will work which will be so so much easier.
Please also be aware that we don’t do student homework here, your job is to learn how learn, learn how to ask questions and learn how to research & evaluate. That’s what happens when you get a job, better to learn now than get a roasting at your desk.
Thank you @Jeff-UK and @descartes.
I’m building an IoT-based weather station using a Raspberry Pi and sensors. I need to send data to the cloud via a LoRaWAN Gateway since there’s no internet access on site. I’ve used Arduino-based LoRa nodes with a Dragino Gateway successfully.
Does it have to be a Pi that is doing the sensor collection?
Because as outlined above, it is one of the harder platforms to implement a stack on. If it has to be a Pi, then you could use an AT-command driven module on a HAT - like the PiSupply RAK811 which is the last thing I used to do that which will take care of any timing issues critical for LoRaWAN whilst you do the sensing.
Otherwise there are sooooo many Arduino based boards that can do LoRaWAN it would be simpler for you to suggest options based on your local suppliers in India.
I have a bunch of LHT65N-E5 that I want to use as loggers, at least for now (LoRaWAN use is planned for later)
I made a script to synchronize their timestamp with my computer’s clock, set them to ABP (AT+NJM=0) so that they don’t need a network, and set the recording interval to 3600000ms (AT+TDC=3600000). I checked that all the settings and clocks are correctly set, and they are.
Yet, after I activated all my devices at the same time with a long press on the ACT button until it blinked, I noticed that some of them get delayed in their recordings. They didn’t blink 60 min later, but 65 to 95 min later. Some of them, on the other hand, correctly woke up 60 min later and made their record as planned.
I checked timestamp, TDC and NJM settings again, and they are correct for all devices, late ones included.
Any ideas? A lower frequency would make delays non-issues, but unfortunately I cannot afford wakes more often than once per hour battery-wise, therefore such delays are signifcant issues for comparison purposes.
You may strike lucky and someone knows the answer, but please be aware that this forum is primarily for LoRaWAN & TTN/TTI, not so much for general product support of something that could be used for LoRaWAN but isn’t. That is to say that we are great at LW, individual product features not so much.
