For the most part, notwithstanding, and positively with regards to the TTN Community such versatile GW’s as in dynamic while moving are debilitate as they are conceivably problematic to different clients. Best practice for (particularly static) hubs is to enabe ADR - the sign strength information for that can be purturbed by portable GW’s making the NS think the hub unexpectedly is in scope of a more grounded GW than typical, driving hub to change conduct, then, at that point causing signal loses when GW continues on or also a GW will report a deminishing sign which again makes NS change Node conduct to redress - consuming battery and diminishing field life.
Aakil \working at Mr.furniture www . mr furniture . ae
