screw holes for Raspberry PI, Arduino, Beagle Bone, stackable and so much
Awesome documentation , for outdoor GW, a must
US $1.46 incl. shipping - node enclosure ?
JST cable/connector sets
China National Day , holidays from Oct. 1st ~ 8th !
US $2.11 incl. shipping
US $4.09 incl. shipping
I use the larger version of this case for one of my homebrew gateways, the smaller is great for nodes
got it today and after soldering the usual connection DIO1 --> pinX it worked with the LMIC library and the prviously used code for the adafruit feather M0.
the board is 2.54mm wider than the original feather, but it could be a cheap substitute.
attention: the documentation notes the pin wron. look in LoRa.h
and you don’t need to install suggested libryry, because that’s forseen for node to node connection
// Adapted for DIYmall feather clone DIYLoRa32u4 Doc: ss = 19 , Reset = 9 , DIO0 = 26 (from LoRa.h)
// from Exemple Sender: ss = 8 , Rst = 4 , DIO0 = 7
.nss = 8, // chip select on clone (rf95module) see LoRa.h
.rxtx = LMIC_UNUSED_PIN, //
.rst = 4, // reset pin (M0=4)
.dio = {7, // DIO0 is hardwired to 7
5, // DIO1 is jumpered to 5
LMIC_UNUSED_PIN}, // DIO1 is jumpered to unused
have fun :slight_smile:
$2.59 incl. shipping
http://www.ebay.com/itm/10pcs-5-dBi-50-ohm-Antenna-IPEX-Interface-For-3G-LTE-4G-GPRS-GSM-CDMA/352163275596
US $5.80 incl. shipping
US $4.42 incl. shipping
US $9.03 incl. shipping
US $2.62 incl. shipping
US $2.19 incl. shipping
For the 915mhz spectrum folks:
FG9026 - Laird 902 - 928 MHz 8 dBi Fiberglass Omnidirectional Antenna w/ Female N-Type Connector
$83.50 US
http://www.balticnetworks.com/laird-antenna-omni-902-928-mhz-tuned-at-915mhz.html
Just purchased one. Let you know how it goes.
in large quantities, look at aliexpress for air vent plug
