Air202 development board GSM/GPRS
howto store your solar power
Mine seems running at about 0.13A with spikes at 0.4A… I will check again this afternoon.
Pure coincidence… I sticked that same antenna on a the metal enclosure from an HDMI switch and look,
So the groundplane is very important for the swr
Update to bench testing TTIG power consumption here
mSATA SSD Storage Expansion Board for Raspberry Pi
bought this 120GB msata - read 520 MB/s, write 320 MB/s
specs
NL shop
These mSATA to USB adapter boards for Raspberry Pi still require a USB cable for it’s IO interface (and power). Although the model shown above has a compact USB to USB (PCB) adapter, many of these solutions require an external USB to USB cable (and €50 is rather expensive for 120GB when compared to below solution).
A regular cheap(er) 2.5" SATA SSD 120GB with USB 2.0 to SATA adapter can be had for around €20 (240GB for around €30). Works just as well. Although you will need to find a solution for mounting the 2.5" SSD. (I have one taped onto a Raspberry Pi enclosure which hangs in the meter cupboard.)
For more compact single enclosure solutions the SSD PCB can be removed from its 2.5" drive enclosure (which will void warranty) and use a PCB-only USB to SATA adapter with a small USB cable.
no, found it ![]()
but you’re right, it can be done cheaper of course but this HW is for a ‘special’ project
With solution for mounting I had something different in mind than ‘putting it somewhere on a table’.
LOL
wireless 5.8 Ghz A/V signal captured on Android
‘follow’ me umbrella drones
22mm AC 60-500V Big Font Display LED Voltmeter 2,06€
No wind please! ![]()
gave myself a present… a ‘pro’ mouse
take one of these…
https://www.seeedstudio.com/Sipeed-Lichee-Nano-Linux-Development-Board-16M-Flash-WiFi-Version-p-2893.html @$7.90
https://www.seeedstudio.site/media/catalog/product/cache/ef3164306500b1080e8560b2e8b5cc0f/l/i/lichee-nano-16m-flash_wifi-version-main_1_1.jpg
Add an SPI based sx1301/1308 concentrator card…RAK 831/833/24xx/imst/etc… Recompile/port s/w and…?
5 more KISS-LoRa devices ready for deployment!
18650’s
Old school PCB…
