TTN GATEWAY central 2
It surely is still rebooting, maybe even more often than before. (I could extract some numbers if anyone’s interested.) But, for me, such reboots have never been an endless loop like for some others, but (apart from its daily scheduled reboot for firmware upgrades) only occur after running into some unexpected problem. Like after MQTT errors, or after something new I’ve seen 225 times now since July 17th (GitHub #52):
LORA: Kick LoRa module with ACK afte
*** assert ../src/app_lora.c:842:w == size:LORA Uart write should be blocking```
For me the major improvement is that the LoRa module has not failed receiving packets in the past 2.5 weeks, which earlier very often happened to my gateway after a reboot (#29). (Or maybe it now reboots itself again when things go south.)
I’ve “only” had to manually reboot the gateway 3 times since July 17th, as it sometimes does not like its network connection after it reboots itself, so will not forward the packets it nicely receives (#8). Still 3 times too many of course; it still needs a Raspberry Pi to monitor it, and still needs to be accessible for manual intervention, though I could make the Pi trigger the reboot…
@BoRRoZ
Thanks for the info… unfortunately the gateway is running unattended at another location.
As the backend knows which version of the software it updates the gateway with its kind of strange not to show that in the console info of the gateway.
agree …
You can use http://noc.thethingsnetwork.org:8085/api/v2/gateways/your-gateway-id which yields something like:
   "timestamp":"2018-08-06T14:32:32.171951235Z",
   "authenticated":true,
   "uplink":"579098",
   "downlink":"4124",
   "location":{
      "latitude":32.379912,
      "longitude":1.63503,
      "source":"REGISTRY"
   "platform":"The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.5-fa89b993 (2018-07-17T08:11:52Z)",
   "gps":{
      "source":"REGISTRY"
   "time":"1533565952171951235",
   "rx_ok":579098,
   "tx_in":4124
I have seen them two times, note the cut-off message on the line before.
2018-07-26 09:59:43.821334 LORA: Kick LoRa module with ACK after not acked it for 60s
2018-07-26 09:59:43.821777 LGMD:Inva
2018-07-26 09:59:43.821800 *** assert …/src/app_lora.c:842:w == size:LORA Uart write should be blocking
2018-08-05 19:58:04.591429 MON: heap usage: 278KB (283KB), free: 61KB
2018-08-05 19:58:05.303908 LORA: Kic
2018-08-05 19:58:05.304065 *** assert …/src/app_lora.c:842:w == size:LORA Uart write should be blocking
@arjanvanb
Thanks… your hint to use http://noc.thethingsnetwork.org:8085/api/v2/gateways/my-gateway-id worked and is showing Firmware v1.0.5-fa89b993 (2018-07-17T08:11:52Z)
So the gateway seems to have been successfully updated. And it looks as it is running ok and stable.
Thanks.
Some statistics can be retrieved from the NOC data:
curl 'http://noc.thethingsnetwork.org:8085/api/v2/gateways' | jq '.statuses[].platform' | sort | uniq -c
…shows how many TTN Gateways use which combination of bootloader and firmware:
   4 "The Things Gateway v1 - BL r0-00000000 (2106-02-06T06:28:16Z) - Firmware v0.0.0-00000000 (2106-02-06T06:28:16Z)"
   2 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v0.0.0-00000000 (2106-02-06T06:28:16Z)"
 244 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.0-917719b9 (2017-06-26T17:59:33Z)"
   1 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.1-4129a80e (2018-02-19T17:51:05Z)"
   2 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.1-91648b7e (2018-03-13T16:48:17Z)"
   1 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.1-91648b7e (2018-03-13T18:56:50Z)"
   8 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.1-facdef23 (2018-02-14T08:16:22Z)"
 388 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.2-475aef56 (2018-03-15T09:35:00Z)"
   3 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.2-475aef56 (2018-03-15T09:43:08Z)"
  62 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.2-475aef56 (2018-03-15T10:16:13Z)"
   4 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.3-2c56ce09 (2018-03-22T12:02:04Z)"
  22 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.3-2c56ce09 (2018-03-22T12:20:52Z)"
   5 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.3-2c56ce09 (2018-04-04T12:45:55Z)"
   5 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.3-2c56ce09 (2018-04-04T12:54:45Z)"
   1 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.3-2d743f4f (2018-04-10T09:02:25Z)"
   1 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.3-485eaceb (2018-04-21T15:57:49Z)"
   1 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.3-485eaceb (2018-04-22T10:28:33Z)"
   2 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.3-5f315131 (2018-04-23T16:14:51Z)"
   1 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.3-a89c1c64 (2018-04-24T08:55:59Z)"
   4 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.3-bbc65da8 (2018-04-26T11:04:44Z)"
   2 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.3-fd0901ae (2018-04-16T12:13:14Z)"
  35 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.4-a7beae91 (2018-05-02T11:06:21Z)"
 767 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.5-fa89b993 (2018-07-17T08:11:52Z)"
   1 "The Things Gateway v1 - BL r2-c463e87e (2018-02-23T14:42:40Z) - Firmware v0.0.0-00000000 (2106-02-06T06:28:16Z)"
   1 "The Things Gateway v1 - BL r2-c463e87e (2018-02-23T14:42:40Z) - Firmware v1.0.1-56827f14 (2018-02-24T12:25:24Z)"
  13 "The Things Gateway v1 - BL r2-c463e87e (2018-02-23T14:42:40Z) - Firmware v1.0.2-475aef56 (2018-03-15T09:35:00Z)"
   2 "The Things Gateway v1 - BL r2-c463e87e (2018-02-23T14:42:40Z) - Firmware v1.0.2-475aef56 (2018-03-15T10:16:13Z)"
   3 "The Things Gateway v1 - BL r2-c463e87e (2018-02-23T14:42:40Z) - Firmware v1.0.3-2c56ce09 (2018-03-22T12:20:52Z)"
   1 "The Things Gateway v1 - BL r2-c463e87e (2018-02-23T14:42:40Z) - Firmware v1.0.3-2c56ce09 (2018-03-27T12:06:47Z)"
   1 "The Things Gateway v1 - BL r2-c463e87e (2018-02-23T14:42:40Z) - Firmware v1.0.3-2c56ce09 (2018-03-28T18:11:40Z)"
   1 "The Things Gateway v1 - BL r2-c463e87e (2018-02-23T14:42:40Z) - Firmware v1.0.3-2c56ce09 (2018-04-04T12:47:15Z)"
   1 "The Things Gateway v1 - BL r2-c463e87e (2018-02-23T14:42:40Z) - Firmware v1.0.3-2c56ce09 (2018-04-04T12:54:45Z)"
   1 "The Things Gateway v1 - BL r2-c463e87e (2018-02-23T14:42:40Z) - Firmware v1.0.3-3fa4f0fb (2018-04-23T11:34:32Z)"
   1 "The Things Gateway v1 - BL r2-c463e87e (2018-02-23T14:42:40Z) - Firmware v1.0.3-485eaceb (2018-04-21T15:57:49Z)"
   1 "The Things Gateway v1 - BL r2-c463e87e (2018-02-23T14:42:40Z) - Firmware v1.0.3-5f315131 (2018-04-23T16:14:51Z)"
   2 "The Things Gateway v1 - BL r2-c463e87e (2018-02-23T14:42:40Z) - Firmware v1.0.4-6f436cd9 (2018-07-09T08:31:38Z)"
   2 "The Things Gateway v1 - BL r2-c463e87e (2018-02-23T14:42:40Z) - Firmware v1.0.4-a1cf7724 (2018-07-04T15:41:38Z)"
   5 "The Things Gateway v1 - BL r2-c463e87e (2018-02-23T14:42:40Z) - Firmware v1.0.4-a7beae91 (2018-05-02T11:06:21Z)"
   1 "The Things Gateway v1 - BL r2-c463e87e (2018-02-23T14:42:40Z) - Firmware v1.0.4-ae7f291f (2018-07-03T19:24:41Z)"
  41 "The Things Gateway v1 - BL r2-c463e87e (2018-02-23T14:42:40Z) - Firmware v1.0.5-fa89b993 (2018-07-17T08:11:52Z)"
   1 "The Things Gateway v1 - BL r2-c463e87e (2018-02-23T14:42:40Z) - Firmware v1.0.5-fa89b993 (2018-07-25T10:28:56Z)"
Not sure what the different dates for the same versions mean.
Using jq '.statuses[].platform' | sed 's/ - BL.*/"/' | sed 's/SC/Single-channel/' | sed 's/[ -][cC]hannel.*/-channel DIY/' | sed 's/Kerlink.*/Kerlink/' | sort | uniq -c | sort gets one a rough idea of the popular gateways. But only the TTN Gateway seems to have a well-defined name (which is shortened by the sed 's/ - BL.*/"/' part, just like the suffixes of all Kerlinks and most single-channel and multi-channel gateways are removed in the command above):
  61 "your name"
  75 "Multi-channel DIY
  81 "LoRaGo DOCK"
 323 "Kerlink
 333 "LORIX One"
 344 "Lorank"
 345 "ESP32"
 363 "MultiTech SPI"
 435 "linux"
 537 "ESP8266"
 552 "MultiTech"
 592 "LG01/OLG01"
 906 "Single-channel DIY
1644 "The Things Gateway v1"
3027 "IMST + Rpi"
6899 null
All this does not take into account when a gateway was last active.
Full output of first command
   2 " "
   1 " Pycom LoPy"
   1 "(FPGA 0, DSP 0, HAL DEV_6.0.0-4)"
   1 "(FPGA 1, DSP 0, HAL 0.0.1)"
   2 "(FPGA 46, DSP 35, HAL 3.3.0)"
   3 "(FPGA 58, DSP 35, HAL 3.6.0)"
   8 "(FPGA 58, DSP 35, HAL 4.0.1-klk3)"
   1 "(FPGA 58, DSP 35, HAL 5.0.0)"
  22 "(FPGA 61, DSP 37, HAL 5.1.0)"
   8 "(FPGA 61, DSP 37, HAL 5.1.0-klk1)"
   3 "(FPGA 61, DSP 37, HAL 5.1.0-klk5)"
  10 "(FPGA 61, DSP 37, HAL DEV_5.1.0)"
  10 "(FPGA 62, DSP 37, HAL 5.1.0)"
   1 "1 CH Gateway RasPi"
   1 "1-CH Gateway"
   2 "8266"
   1 "AAEON AIOT-ILRA01"
   1 "AMi Immenstaad LoRa"
   1 "Advantech UTX-3117 LoRaWAN GateWay"
   1 "Anapamu_Gateway"
   1 "Andre Torre-Neto"
   2 "Andy"
   1 "Andys Test Gateway"
   1 "Arjan Forkink"
   1 "Arjen Test Gateway"
   1 "Ark's home gateway"
   1 "B.J. van Drunen Littel"
   1 "BKK LORA Gateway"
   1 "Bart"
   1 "Bass Dee"
   2 "BatiLORAGateway01"
   1 "BukaLapak SC Gateway"
   1 "Burelade"
   1 "Burnside LoRa"
   1 "BuzZz SC Gateway"
   1 "CCG LoraWAN Gateway"
   1 "Camnexus Loa"
   2 "Capelle Gateway"
   1 "ChauQue's Gateway"
   1 "Chowkah"
   1 "Chris SCGateway"
   1 "Coeus Single Gateway"
   1 "Coopers Gateway"
   1 "CyngorGwynedd"
   1 "DANET LORA Gateway"
   1 "DIY Raspberry pi Multi-channel DIY gateway"
   1 "DIY SX1276 RPI Zero W"
   1 "DIY gateway RPi + SX1301 Ref Des"
   1 "DIY v0.1"
   1 "DPTechnics Test-GW-01"
   1 "David Brown"
   1 "DeepWell Gateway"
  12 "Definium"
   1 "Development Gateway"
   9 "Dragino LG01-JP"
   1 "Dragino Test Gateway"
   2 "Dual Channel Gateway"
   1 "EES SC Gateway"
   1 "EGAT Krabi Lora"
   1 "EMBIT-GW1301"
   1 "ES32"
   1 "ESMCELL.CO ESMG001"
   1 "ESP32 433"
   1 "ESP32 LoRa"
   2 "ESP32 TTGO"
 346 "ESP32"
   2 "ESP32-2"
   1 "ESP32-TTGO"
   2 "ESP32TTGO"
   1 "ESP8266 + SX1276"
   1 "ESP8266 RF95"
   5 "ESP8266 RFM95w"
   1 "ESP8266 with RFM95W"
 537 "ESP8266"
   2 "ESP8266+RFM95W"
   1 "ESP8266-RFM95W-WeMos"
   1 "ESP8285"
   1 "Elsys ELG"
   1 "EmOne SCLORA-LGW001-iCAS923TH"
   1 "EmOne SCLORA-LGW002-iCAS923TH"
   1 "ExpEmb"
   1 "FMI Gateway"
   1 "FiPy V1"
   1 "Flab Gateway"
   1 "GSMSTM32"
   1 "GW ch ztag.io"
   1 "GWCF0001 BRITECH"
   1 "GWESP8266Hallard"
   1 "Gateway One"
   1 "Gateway canal simples "
   2 "Gateway"
   2 "GaussCR"
   1 "Gemtek Femto"
   1 "Gemtek IOT Femto Gateway"
   1 "Gemtek IoT Femto Gateway"
   4 "Gemtek WLRGFM-100"
   4 "Gemtek"
   1 "Geof Baum"
   1 "George BOYD RATCLIFF"
   1 "German"
   1 "Gill Pi Zero W"
   1 "GizmolO"
   1 "GrabGuard"
   1 "GreenIO"
   1 "Habsburg Gateway"
   1 "Hardinxveld-Gateway"
   1 "Heltec ESP32 433 MHz"
   1 "Heltec ESP32 868 MHz"
   1 "Heltec ESP32"
   1 "Henk Dick"
   1 "Homebrew  DIY iC880A + Raspi Zero W (Solar Test)"
   1 "Homemade v1.0"
   2 "IFSC -  Semtech Raspberrypi 3 + LRF2S001 Micro gateway LoRaWAN 8 Canais 915MHz + packet forwarder"
3028 "IMST + Rpi"
   1 "IMST Gateway Lite Gateway"
   1 "IMST GmbH WiMOD Lite Gateway"
   1 "IMST Lite Gateway"
   2 "IMST Lite"
   1 "IMST LoRa Lite Gateway"
   3 "IMST RAK NPI"
   3 "IMST iC880A"
   1 "IMST"
   1 "IOT Factory 3G-GPS"
   1 "ISRC GWL-110"
   1 "ISRC ISRC-100"
   2 "Iotomuj"
   1 "Isaac MArlon"
   1 "J. Mesu"
   1 "JC Gateway"
   1 "JH Gateway"
   1 "Jattupong"
   1 "JeeWeetje"
   1 "JetHouse LoRa Gateway"
   1 "Jimmy Smith Gateway"
   1 "Jota S.A."
   1 "KCR"
   1 "KIWI"
   1 "KIWI-TEC TLG29"
   1 "KONA Pico"
   1 "KW_LoRa_test"
   1 "Kerlink 20dBm"
   1 "Kerlink Femtocell"
   1 "Kerlink IOT Station 868"
   1 "Kerlink Ifemtocell indoor"
   1 "Kerlink Ifemtocell"
   1 "Kerlink IoT Gateway"
   1 "Kerlink IoT Station (Concentrator: SPI0 868 MHz, 27dBm version)"
   1 "Kerlink IoT Station 868"
   9 "Kerlink IoT Station"
   3 "Kerlink IoT station"
   2 "Kerlink IoTStation"
   1 "Kerlink Iot Station"
   1 "Kerlink Kerlink Wirnet Station "
   1 "Kerlink LoRa Gateway Wirnet 868 MHz"
   4 "Kerlink LoRa IoT Station 868"
   5 "Kerlink LoRa IoT Station 923"
  11 "Kerlink LoRa IoT Station"
   4 "Kerlink LoRa IoT station"
   1 "Kerlink LoRa station 20dBm, sold until May 2015"
   8 "Kerlink LoRaIOT Station (Wirnet)"
   1 "Kerlink LoRaIOT Station"
   1 "Kerlink Lobaro.de"
   1 "Kerlink Lora IOT Station 868"
   1 "Kerlink LoraIoT station 868"
   2 "Kerlink Outdoor LoRa basestation"
   1 "Kerlink Station"
   1 "Kerlink V1"
   1 "Kerlink WIRNET STATION 868 MHZ"
   1 "Kerlink Wigrid Station"
   1 "Kerlink WirNet V2.0"
   1 "Kerlink WirNet v2"
   1 "Kerlink Wirenet iFemtoCell"
   1 "Kerlink Wirestation"
   2 "Kerlink Wirgrid"
   2 "Kerlink Wirnet IoT Station"
   1 "Kerlink Wirnet LoRa IoT Station 868"
   1 "Kerlink Wirnet LoRaIOT Station"
   1 "Kerlink Wirnet Station 868 MHz"
   8 "Kerlink Wirnet Station 868"
  25 "Kerlink Wirnet Station"
   1 "Kerlink Wirnet iFemtoCell 923"
   3 "Kerlink Wirnet iFemtoCell"
   2 "Kerlink Wirnet iFemtocell"
   1 "Kerlink Wirnet station 868"
   3 "Kerlink Wirnet"
   1 "Kerlink iFemToCell"
   1 "Kerlink iFemto"
  19 "Kerlink iFemtoCell"
   5 "Kerlink iFemtocell"
   2 "Kerlink ifemtocell"
   1 "Kerlink typ1"
   1 "Kerlink wirnet"
 168 "Kerlink"
   1 "Komtek IoT"
   1 "L-tecynology & CES"
   1 "LAIRD Sentrius_RG186"
 592 "LG01/OLG01"
   4 "LG02/OLG02"
 333 "LORIX One"
   2 "Laird  RG186"
   1 "Laird  RG191"
   1 "Laird / EBV RG186 Indoor"
   1 "Laird RG1"
  24 "Laird RG186"
   1 "Laird RG191 LoRa Gateway"
  17 "Laird RG191"
  13 "Laird RG1xx"
   1 "Laird RM191"
   1 "Laird SENTIRUS RG1xx"
   1 "Laird SENTRIUS RG1XX"
   1 "Laird Sentries RG1xx"
   2 "Laird Sentrius RG1"
   1 "Laird Sentrius RG168"
  20 "Laird Sentrius RG186"
   1 "Laird Sentrius RG191 LoRa Gateway"
   7 "Laird Sentrius RG191"
   1 "Laird Sentrius RG1XX"
   1 "Laird Sentrius RG1xx Series"
   5 "Laird Sentrius RG1xx"
   1 "Laird Sentrius RG91"
   1 "Laird Sentrius Rg186"
  12 "Laird Sentrius"
   1 "Laird Sentruis RG191"
   1 "Laird Technologies Sentrius RG186"
   1 "Laird Technologies Sentrius"
   1 "Laird"
   1 "LairdTech Sentrius Series RG1xx"
   1 "Lairdtech  Sentrius Rg1xx"
   1 "Lairdtech RG186"
   2 "Lairdtech Sentrius RG186"
   1 "Lairdtech Sentrius RG191 Gateway"
   2 "Lairdtech Sentrius RG1xx"
   1 "Lindseth"
   1 "Link Labs LL-BS-8"
   1 "Link Labs Outdoor Gateway"
   8 "LinkLabs Blowfish + Rpi"
   1 "Linux"
   1 "LoPy LoPy"
   1 "LoPy LoRaWAN Nano-Gateway"
   1 "LoPy module"
   3 "LoPy"
   1 "LoPy4"
   1 "LoRa GC"
   1 "LoRa Gateway "
   2 "LoRa Gateway Packet Forwarder /  RasPi + RAK831 (SX1301) https://github.com/Lora-net/packet_forwarder"
   1 "LoRa Gateway Sys1"
   1 "LoRa Gateway Sys2"
   1 "LoRa Gateway board SX1308 Raspberry Pi LoRa Gateway Board"
   1 "LoRa Gateway"
   1 "LoRa SC Gateway"
   2 "LoRaGo DOCK - ESP8266"
   1 "LoRaGo DOCK - WIFIPOWER"
  81 "LoRaGo DOCK"
   2 "LoRaGo Dock"
   1 "LoRaPi Hat"
   1 "LoRa_Fritz"
   1 "LoRun G300"
   1 "Lopy Pycom nano-gateway"
   1 "Lopy"
   1 "Lora"
   1 "Lorank 8 Lorank 8-868"
   1 "Lorank 8 Lorank8-868"
   4 "Lorank 8"
 344 "Lorank"
   2 "Lorelai (MaZ London)"
   1 "Lucas Garelli"
   2 "Luiz Mello"
   1 "MGRA_LoRa"
   1 "MTAC-LORA nanopi neo"
   2 "MacBart Gateway"
   1 "Maid In Iran IoTLoGW_1"
   2 "Marek Ulwański"
   1 "Mariano"
   1 "Mario Mollo"
   1 "Marqus Gateway"
   1 "Match X box-mx1701"
   2 "Match X"
   1 "MatchX 1702"
   3 "MatchX Box MX1701"
   1 "MatchX Box MX1702"
   2 "MatchX Box"
  10 "MatchX MX1701"
   9 "MatchX MX1702"
   1 "MatchX MatcX 8ch gateway"
   1 "MatchX MatchBox"
   1 "MatchX Matchbox"
   1 "MatchX One"
   2 "MatchX box-mx1701"
   5 "MatchX"
   1 "Matchx MX1701"
   1 "Miromico Pico Gateway"
   1 "Mounoy Dev Gateway"
   1 "Multi-channel DIY Solar gateway Raspberry Pi with IMST iC880A /w Solar + UMTS"
   2 "Multi-channel DIY gateway  Raspberry Pi with iC880A"
   1 "Multi-channel DIY gateway Beagle Bone Black with IMST iC880A"
   1 "Multi-channel DIY gateway ESP32 based with RAK/Rising HF concentrator"
   1 "Multi-channel DIY gateway ESP32_GW"
   1 "Multi-channel DIY gateway GW-01"
   1 "Multi-channel DIY gateway MTAC868"
   1 "Multi-channel DIY gateway Olimex A13-Olinuxino with RAK831"
   1 "Multi-channel DIY gateway OrangePi Zero with IMST iC880A"
   1 "Multi-channel DIY gateway RAK"
   1 "Multi-channel DIY gateway RPI Zero + RPI Zero Gateway Hat"
   1 "Multi-channel DIY gateway RPi with RisingHF  RHF0M301-868"
   1 "Multi-channel DIY gateway Raspberry PI with RHF3M076"
   1 "Multi-channel DIY gateway Raspberry PI with RisingHF board"
   1 "Multi-channel DIY gateway Raspberry PI with SX1308 and two SX1257"
   1 "Multi-channel DIY gateway Raspberry Pi 3 with RHF0M301"
   1 "Multi-channel DIY gateway Raspberry Pi RisingHF "
  29 "Multi-channel DIY gateway Raspberry Pi with IMST iC880A"
   4 "Multi-channel DIY gateway Raspberry Pi with Link Labs Gateway Board"
   1 "Multi-channel DIY gateway Raspberry Pi with MTAC 868 board"
   1 "Multi-channel DIY gateway Raspberry Pi with MTAC Board"
   1 "Multi-channel DIY gateway Raspberry Pi with MTECH Card"
   1 "Multi-channel DIY gateway Raspberry Pi with Mcard"
   1 "Multi-channel DIY gateway Raspberry Pi with Multi-Tech  mCard"
   3 "Multi-channel DIY gateway Raspberry Pi with Multitech mCard"
   1 "Multi-channel DIY gateway Raspberry Pi with RAK831"
   2 "Multi-channel DIY gateway Raspberry Pi with RHF0M301"
   4 "Multi-channel DIY gateway Raspberry Pi with RisingHF RHF0M301"
   1 "Multi-channel DIY gateway Raspberry Pi with RisingHF board"
   1 "Multi-channel DIY gateway Raspberry Pi with will's Gateway hat V2"
   1 "Multi-channel DIY gateway Raspberry Pi, SX1301 HAT Will Whang"
   1 "Multi-channel DIY gateway Sinovoip Banana Pi M2 Ultra with an IMST iC880A concentrator"
   5 "Multi-channel DIY gateway"
  37 "MultiTech Conduit AEP"
   1 "MultiTech Conduit AP mLinux"
   1 "MultiTech Conduit Access Point AEP"
   1 "MultiTech Conduit MTCDT-H5-247A"
   6 "MultiTech Conduit mLinux"
   1 "MultiTech MTCAP"
 363 "MultiTech SPI"
 552 "MultiTech"
   2 "MultiTech-x86"
   1 "My Dragino Gateway"
   1 "MyIOT LORA Gateway"
   1 "NEMEUS PICOGATEWAY"
   1 "NICERF"
   1 "NPi RAK831(spi)"
   2 "NURD LoRa Gateway Test"
   2 "Nanne APJ Kuperus"
   1 "Nemeus Mg003"
   3 "Nemeus Pico Gateway"
   1 "Nemeus Pico gateway"
   1 "Neosen Pi-1308"
   1 "NiceRF LoRaWAN-Gateway-PF"
   1 "NightPi Gateway 001"
   1 "NovaNode"
   1 "PCD Control Gateway"
   1 "PCVT LoRaWAN BGVT0002"
   1 "PE1NZI MBrus BEMMEL"
   1 "PKT-SOS Gateway"
   1 "PNBL_INMRST_00"
   1 "PYCOM LOPY"
   2 "Pablo Bravo"
   1 "Paolo Meridiani"
   1 "Penpen's 1 Channel GW"
   2 "Pi 3"
   1 "Pi TechL SingleGW"
   1 "Pi-Gate"
   1 "PrimoFirst"
   1 "PyCom FiPy NanoGateway"
   1 "PyCom FiPy"
   1 "PyCom LoPy - DIY - prototype LoPy"
   1 "PyCom LoPy Nano Gateway"
   1 "PyCom LoPy NanoGateway"
   2 "PyCom LoPy with LoRaWAN Nano-Gateway, single channel 0"
   3 "PyCom LoPy"
   1 "PyCom LoPy1"
   1 "PyCom LoPy4 Nano Gateway"
   1 "PyCom LoPy4"
   1 "PyCom Lopy4"
   1 "Pycom  LoPy v.1.0"
   4 "Pycom FiPy"
   1 "Pycom Fipy / Nanogateway config"
   2 "Pycom Fipy"
  14 "Pycom LoPy"
   1 "Pycom LoPy1"
   6 "Pycom LoPy4"
   1 "Pycom Lopy 1"
   9 "Pycom Lopy"
   1 "Pycom Nano Gateway Lopy"
   1 "Pycom NanoGateway"
   1 "Pycom Single channel DIY gateway"
   1 "Pycom nano gateway Pycom Lopy 1.0r"
   1 "Pycom nanogate FiPy-lorawan-nanogate"
   1 "R&D Single Channel Pycom"
   1 "RAK 831"
   1 "RAK RAK 831"
   1 "RAK Wireless RAK831"
   4 "RAK831 + OPi"
   1 "RAK831 + OrangePiZero"
   1 "RAK831 + Rpi"
   1 "RAK831 +Opi"
   2 "RAK831"
   1 "RAK831-BeagleBoneBlack"
  12 "RAK833 + Rpi"
   1 "RAKwireless RAK831"
   1 "RAMOND BELMO"
   1 "RATHINASAMY"
   1 "RATHINASAMYS"
   1 "RCN SC Gateway"
   9 "RFI Engineering L-gateway"
   1 "RFI Engineering RE.41.LGTW"
   1 "RFI Engineering S-gateway"
   2 "RPI 3B "
   1 "RPI3 (spi)"
   3 "RPI3 IMST IC880A(spi)"
   1 "RPI3 RAK831(spi)"
   1 "RPVS"
   1 "RPi Zero W Gateway"
   2 "RPi"
   1 "RPi0 1ch Gateway"
   1 "RPi3-LoRa-1ChnlGW"
   1 "Raspberry MTAC Lora"
   1 "Raspberry Pi 3 + RAK831"
   1 "Raspberry Pi 3 w/ Rising HF RHF0M301"
   1 "Raspi Single Channel Gateway"
   1 "Raspi with IMST iC880A"
   1 "Raspi"
   1 "Ray Belmo"
   1 "Rene Arnhold"
   1 "Rising HF 2001 RPi Model 3 with Rising HF Discovery Kit"
   1 "Rising HF RHF0M301"
   1 "Rising HF RHF2S0084GP"
   1 "Rising HF RHF2S008P4G"
   1 "Rising HF RHF2S024"
   1 "RisingHF + RPi"
   1 "RisingHF RHF0M301"
   2 "RisingHF"
   1 "Robin Quetin"
   1 "Robustel R3000"
   3 "Robustel R3000-LG"
   1 "Robustel R3000-LG4LA"
   1 "Robustel R3000-LGNUA"
   1 "SC Gateway Medzany1"
   1 "SC Gateway Udenhout"
   1 "SC Gateway ees lab"
 108 "SC Gateway"
   1 "SC Gateway-p"
   1 "SC Gw jkrt64"
   3 "SC Lora Gateway"
   1 "SC Lorawan"
   1 "SCG"
   1 "SCLORA LGW002AS923TH (iCAS923TH)"
   1 "SC_Gateway"
   1 "SEParkingGateway"
   1 "SY"
   1 "SY2 Lora Gateway"
   1 "Saint LoraWAN Gateway"
   1 "Seeedstudio RisingHF"
   1 "SemTech"
   1 "Semind"
   1 "Semtech IoT Starter Kit"
   1 "Semtech LoRa Picocell Gateway"
   1 "Semtech PicoCell Using 2nd Sub-band - TTN Standard"
   1 "Semtech PicoGW"
   1 "Semtech Picocell gateway"
   1 "Semtech Picocell"
   1 "Semtech SX1308 Picocell gateway"
   1 "Semtech This gateway operates on sub-band 1."
   3 "Semtech pico"
   1 "Semtech picocell"
   1 "Sentient Computing MatchX box-mx1702"
   1 "Sentries RG191"
   1 "Sentrius Laird RG191"
   1 "Sentrius RG1"
   1 "Sentrius RG186 LoRa Gateway @ WIFIPOWER  QUINT-FONSEGRIVES RG186"
   3 "Sentrius RG186"
   1 "Sentrius RG191 Gateway"
   2 "Sentrius RG191"
   2 "Sentrius"
   1 "SequiturGW2"
   1 "Simulator"
   1 "Sing_Chan_Gw_DC"
   1 "Single Ch GW TSoft"
   1 "Single Channel GW GMO"
   1 "Single Channel Gateway "
   1 "Single Channel Gateway HB9LEB"
 709 "Single Channel Gateway"
   1 "Single-channel DIY gateway "
   1 "Single-channel DIY gateway FOX TTN"
   1 "Single-channel DIY gateway FiPy board / 868.1 Mhz SF5"
   2 "Single-channel DIY gateway FiPy"
   1 "Single-channel DIY gateway Fipy V1.0 868MHz"
   1 "Single-channel DIY gateway Gateway"
   1 "Single-channel DIY gateway IC880A"
   2 "Single-channel DIY gateway LOPY"
   1 "Single-channel DIY gateway LoPy "
   2 "Single-channel DIY gateway LoPy Based DIY Gateway"
   3 "Single-channel DIY gateway LoPy Nano Gateway"
   1 "Single-channel DIY gateway LoPy by Pycom"
   1 "Single-channel DIY gateway LoPy nano gateway"
  14 "Single-channel DIY gateway LoPy"
   1 "Single-channel DIY gateway LoPy1.0r"
   2 "Single-channel DIY gateway LoPy4"
   3 "Single-channel DIY gateway Lopy"
   1 "Single-channel DIY gateway Lopy1"
   1 "Single-channel DIY gateway Lopy4 Nano Gateway"
   1 "Single-channel DIY gateway Lopy4"
   1 "Single-channel DIY gateway Nano Gateway LoPy"
   1 "Single-channel DIY gateway NanoGateway Pycom"
   2 "Single-channel DIY gateway PyCom LoPy"
   1 "Single-channel DIY gateway Pycom LR1"
   1 "Single-channel DIY gateway Pycom LoPy 2.0"
   4 "Single-channel DIY gateway Pycom LoPy"
   1 "Single-channel DIY gateway Pycom LoPy4"
   1 "Single-channel DIY gateway Pycom LoRa V1.0"
   2 "Single-channel DIY gateway Pycom Lopy"
   1 "Single-channel DIY gateway Pycom"
   1 "Single-channel DIY gateway RPi3"
   1 "Single-channel DIY gateway Raspberry Pi 3 Model B GPS/LoRa Hat"
   1 "Single-channel DIY gateway Raspberry Pi"
   1 "Single-channel DIY gateway lopy nanogateway"
   1 "Single-channel DIY gateway lopy"
   1 "Single-channel DIY gateway lopy4"
   1 "Single-channel DIY gateway pycom lopy "
   1 "Single-channel DIY gateway pycom"
   1 "Single-channel DIY gateway pycom_lopy"
   1 "Single-channel DIY gateway pycom_lopy4"
  10 "Single-channel DIY gateway"
   1 "Smartiko"
   1 "Sngl Chnl Gtwy@SamSwion"
   2 "SysLora Gateway"
   1 "T77I844.01"
   1 "TEKTELIC Kona Pico"
   2 "TEKTELIC Pico Gateway"
   6 "TTGO"
   1 "TecSUS PCDM-Lopy4"
   2 "Tektelic Kona Pico"
   1 "Tektelic Pico"
   1 "Tektelik Pico"
   1 "Test Gateway"
   1 "TestGW915"
   1 "TestMs"
   1 "The Things Gateway lopy"
 387 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.2-475aef56 (2018-03-15T09:35:00Z)"
 768 "The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware v1.0.5-fa89b993 (2018-07-17T08:11:52Z)"
   1 "The Things Products The Things Gateway"
   1 "Things Cumbria Gateway"
   1 "Things Product Things Gateway"
   1 "Til's Gateway"
   1 "UMR Test Gateway"
   1 "UdLoRa"
   1 "UfiSpace Pico Cell T77I844.01"
   1 "Unison RTOS"
   1 "VD test SC Gateway"
   1 "VJBM's Gateway"
   1 "Vega BS-02"
   2 "Vega BS2"
   1 "Vega"
   1 "WINEXT TECHNOLOGY GS5000A GATEWAY"
   1 "Waldpyk_GW001"
   1 "WeMos"
   1 "Wifx LORIX One"
   1 "Will Whang's Electronics SX1308 Raspberry Pi LoRa Gateway Board + Raspberry Pi 3 Model B 1GB RAM"
   1 "Win10 IoT Gateway Raspberry Pi 3"
   1 "Winext GW5000"
   1 "Wireless-Road GW-08 - LoRaWAN gateway"
   1 "Yuan"
   1 "ZTE GW-510"
   1 "atec"
   1 "bashir"
   1 "becreativeiotsensorbox"
   1 "bengau gateway"
   1 "brainzap"
   1 "collisiondemo"
   1 "core_m2m_maekawa_gw"
   1 "delta7"
   1 "denmead-g4dcp"
   2 "donetdisturb"
   1 "dr-t0001"
   1 "dual node "
   1 "esp32"
   1 "eui-008734fffe7f1ba9"
   1 "eui-b827ebb56052ffff"
   1 "eui-b827ebfffe7cab39"
   1 "eui-c83a35fffed024da"
   2 "evandarcy"
   1 "flurp TTN gateway"
   1 "iSingle Channel Gateway"
   1 "iotta gw v1.2"
   1 "laird RG"
   2 "laird RG186"
   1 "laird Sentrius"
   1 "laird rg186"
   1 "laird rg191"
   1 "laird sentrius rg191"
   1 "lairdtech Sentrius RG186"
   1 "lakeside"
   1 "laura1-gateway"
   1 "leafnet.io SCG"
   1 "limi"
 435 "linux"
   1 "loPyGateway loPy"
   1 "lopy"
   1 "matchX Box"
   1 "matchX"
   1 "matchx"
   1 "matchx.io mx1701"
   1 "mfarver-testgw"
   2 "miguelt007"
   1 "mke112"
   1 "modas  MGW2"
   2 "molmc"
   2 "name too long"
   1 "nj gateway dual single"
   1 "nzz"
   1 "pcmg-gateway"
   1 "pi0Gateway"
   1 "prenzlnet"
   1 "pycom LoPY"
   2 "pycom LoPy"
   5 "pycom lopy"
   1 "raspi-sx1276"
   1 "raspibo raspberry + imst"
   1 "ruffasdagut"
   1 "saule"
   1 "seeed"
   1 "semtech picoGW"
   1 "semtech"
   1 "sensaiotech"
   1 "sentrisu RG1xx"
   1 "sentrius Gateway"
   1 "single-channel-gateway"
   1 "singlechan"
   1 "srinivas"
   1 "stefan_gateway"
   1 "taifang_lora_Single Channel Gateway"
   2 "test 2 gateway"
   1 "testforwarder"
   1 "testyour name"
   1 "tony-gateway"
   1 "ttgo"
   2 "ttn-mqtt-proxy: 'Lorank gateway@eradus.eu de kuil'"
  35 "undefined"
   2 "varuna"
   1 "vdSwaluw"
   1 "wireless-road GW-01"
   1 "wugateway"
  61 "your name"
   1 "汉熵通信 LoRaWANV2_CN470"
6904 null
Based on the recent posts on this thread I took a look at the noc for my TTN GW - bought in December commissioned/installed Jan/Feb - delayed as I saw people had serious problems with none working GW’s. As mine installed and worked fine OoTB i decided to leave well alone and had disabled auto updates.
When I look on noc however it shows:-
“The Things Gateway v1 - BL r1-7167873a (2017-06-02T13:48:18Z) - Firmware **v1.0.5-fa89b993 (2018-07-17**T08:11:52Z)”
Implying its been updated to v1.05 despite GW set up as
So either auto update opt out ignored or noc telling porkies! :thinking:
GW has run fine since install despite a couple of power cuts to office and GW being relocated around UK a couple of times for pop-up tests…fortunately haven’t had problems seen by others - so far…and hadn’t seen any reboots that would imply it was updating…strange…
UPDATE:
Just checked things-gateway.local/info to see what GW status says and it shows
So clearly the autoupdate opt out has been ignored! :frowning:
Interesting. Similar situation here. Auto update turned off since no apparent problems, but now I see:
Firmware: v1.0.5-fa89b993 (2018-07-17T08:11:52Z)
Hi all,
We have a TTN Gateway and we want to configure it with a local network, however in order for the gateway to connect to the gateway we need to allow it through its MAC address.
How can we get the MAC address for the gateway?
Thanks,
Ioteelab
You can look it up in your DHCP server.
Are these issues with the firmware the reason the gateways are backordered until March '19?
the 915 mhz version… chip production related I think…
these chips are VERY populair at the moment :wink:
They should be back in stock either end of September or end of October.
Finally working !!! update from SD card never worked, but a colleague helped me with a Microchip programmer and now the gateway is stable and working !
Tried to get the gateway working once more, after some time of inactivity. Today, I managed to update the firmware to v1.0.5. There was a short moment when the gateway seemed to be fully connected. But, it is again back to the sequence of the fourth led flashing, then rebooting. Activation of the gateway appears to be complete.
Screenshot%20from%202018-09-22%2016-44-36 Screenshot%20from%202018-09-22%2016-35-32 Screenshot%20from%202018-09-22%2016-33-37
It could be that the local network is the cause of all trouble. It is a Fritzbox on Xs4all ADSL. But, the gateway has unrestricted access to the internet.
To check an alternative, I also configured the gateway to connect to the internet via my iPhone’s hotspot. But, it all does not make a difference.
I am running out of options for things I can do myself. Not willing to buy additional controllers or toolkits to get low level access to the gateway: no more funds to this device because it has not worked a second yet.
Anybody has suggestions on how to get the gateway connected and working?
Version 1.0.5 is a great improvement, fortunately. Any progress to report on the remaining issues?
And I am wondering: since the Lora issue was addressed, what about the bootloader which was supposed to address the same issue - should I revert to the original version, or keep version 2 installed?
Did you validate that using, e.g., the serial monitor?
True, my gateway rarely needs manual intervention, but it has rebooted itself 522 times just due to the following failing assert, since installing 1.0.5 on July 17th (which is 70 days ago):
(Not every occurrence of the “LORA: Kick LoRa module with ACK after not acked it for 60s” message yields a failing assert. See also GitHub #52.)
No, I did not - I followed the TTN claim for this release. I probably should have written ‘supposedly addressed’.
Hello guys!
I have a TTN gateway connected by cable to a 3G router with a weak signal (with lot of surrounding noise). I don’t have any physical access to the gateway but someone to power / unpower it.
The gateway somehow looses the connection to the router. Before rebooting the gateway, the 2nd LED is blinking fast with the first one ON. This means that the internet connection failed. We suspect that this comes from the poor 3G signal strength.
After rebooting, all LEDs are ON and the data transfer too. Then, it stops after a few hours.
I don’t know the flashed firmware version. Is there a mean to get it remotely?
Do you know how to solve this connection problem?
