Turbo TBS-200
@yomue, if you want to use TTN where you have setup the device, you need to reinstall your gateway and when you get to the section Set up RAK Gateway LoRa® Concentrator, you should follow the instruction Server is TTN.
You appear to have selected the second option to run a server on the gateway - so you’ve got the device setup in the TTN server but your gateway is using a local server.
