Can't delete application
Please ignore message below. I made a mistake. I created an application with name test-application-earvdl rather than test-application-earvdl@ttn. I can delete the application, but have first to remove the devices in it.
I’m quite new to TTN, but I think that I found a bug and don’t know how to deal with it.
I was able to create an application having an ID with the @ symbol in it. Something like “test-application-earvdl@ttn”. I want to delete this application, because it is causing issues. In the TTN web interface the ID for some reason became “test-application-earvdl”. But in the posted mqqt message topics the “@ttn” is still part of the application ID. That causes troubles with my backend integration. Therefore I want to delete the application, but I can’t. When trying, I have to explicitly specify the application ID: test-application-earvdl. When doing so, I get the following error: Application delete error.
Is there a solution?
Thanks,
Erwin
