Hi everyone,
I recently bought a RAK10701-Plus, expecting to connect it to TTN and start checking coverage, just as I had with the older RAK10701-P.
That turned out to be less straightforward than expected. The Plus uses a different protocol, so the backend I had used with its predecessor did not return all the readings to its display.
I built a solution for my own tester, then decided to make it available to others: fieldtester.io.
What does it do?
fieldtester.io receives your tester’s uplinks through a TTN webhook, processes the reception metadata and sends the results back to the device. This brings uplink signal readings, gateway distances where location information is available, and packet-loss information to your tester’s display.
fieldtester.io currently supports five field tester models: RAK10701-Plus, RAK10701-P, RAK10701-L, RAK10706 and Adeunis FTD.
You don’t need a RAK gateway or your own backend server. You do need working TTN coverage and a downlink path to your tester.
Free: get the readings on your tester
If you simply want to check reception in the field, the Free plan gets the readings onto your device without storing measurement locations.
Create an account, configure the webhook in your TTN application and start measuring. A step-by-step guide walks you through the setup.
Pro: record and document your surveys
Pro includes the Free features and adds tools for keeping and analysing your measurements:
Up to three testers.
Every measurement point is recorded and grouped into measurement sessions.
Each session has its own map, colour-coded by signal strength.
Export as CSV, JSON or Excel, including coordinates and all receiving gateways.
Measurements are retained for 365 days.
This is useful for comparing locations, documenting coverage gaps or checking what changed after installing an additional gateway.
Business: plan deployments and work as a team
Business includes the Pro features and expands the service for teams and customer projects:
Up to 25 testers.
Site planning: place pins on the map to assess whether coverage is likely to meet an application’s needs, using your measurements, line-of-sight analysis and active TTN gateways.
A line-of-sight profile for each gateway, showing terrain, buildings and the Fresnel zone alongside measured values.
A combined coverage map across all measurement sessions.
Team access with roles.
Device management: assign testers and maintain device details and status.
Read-only sharing links for individual sessions or the combined coverage map.
PDF reports with your logo for your customers.
Measurement sessions remain available for as long as your Business subscription is active.
The planning tools help you assess potential locations and decide where to measure next. An on-site test remains the way to check actual reception.
Why I built it
A gateway marker on a map doesn’t tell you whether a sensor will work behind a building, near the ground or on the other side of a hill.
I wanted a straightforward way to check those locations, keep the results and understand which gateways actually received each measurement. fieldtester.io has grown from getting the missing readings onto my own tester into a tool for documenting and planning TTN deployments.
The Free plan remains useful on its own. The paid plans add recording, storage, analysis and collaboration tools for those who need them.
Try it and share your feedback
If you have a compatible RAK tester, I’d be happy for you to give it a try:
I’d particularly appreciate feedback from people measuring in different environments. What works well, what is missing, and what would make it more useful for your coverage surveys?
Best regards,
André
