Retrieve data from TTN by using Python SDK
I have a problem in retrieving data from TTN by using Python SDK. I was using python SDK and having a problem. I run the example code from here https://www.thethingsnetwork.org/docs/applications/python/. I have changed the app_id and access_key in that code to my own.
This is the result when I run the code by using Anaconda Prompt:
SDK python
The problem is the data is not continue received from TTN.
Can any one help me?
Rather than posting images the guys best set to provide support for software activities on the forum would wish you to follow:
