ok tnx…
it came from someone who used to collect and polish minerals/stones/cristals… thing like that
what ? $145.00 ? I struck gold !
for some rf experiments I want to remotely switch the node/device antenna’s
bought the chips last year… but now I found complete modules that I will use
cheap IP 67 waterproof outdoor node enclosure with mounting bracket
Hi @BoRRoZ, you really made me laugh with this one. I studiously read all your workbench and bargain postings and often follow the links and sometimes buy samples of the things to try out.
I want to buy one of these… but - for the first time that I can remember - there does not seem to be a link with the image!
Please can you post with a link. Big thanks from me for all your posts.
Hi Tim , I bought long time ago 3 pcs (2 by mistake) 698-2700 Mhz antennas , absolutely not usable for LoRa … but I can’t throw things away '…can be used in the future )
- seller is not to be found anylonger
I bought them for around 10E… they are still available but for a different price
but maybe someday…
update
getting closer to 10€
I’ll make it a bit smaller (and control over I2C)
better use some rf shielding enclosure
I build it as an I2C module So I can use it in some other projects too… plug and play
POC test
huh ?
have to search… but I remember they don’t sell anylonger last time I looked… that’s because @Jeff-UK bought them all
- found it
sometimes here
Sorry! - I only took a half dozen! Work well with the Pilot & re-housing Laird RG186’s I bought them as smaller/compact options as alternate to usual EZ enclosure : Outdoor Enclosure, 1 Ethernet, 4 N-type holes » E-zy.net
(They look to be old (think maybe 1990’s Nortel? sourced from EZ) CATV break-out/repeater cases - nicely made…5x Cable glands or N-type vs 4 for the SOE01 )
actually I could do with a couple more so if anyone finds some please shout here! I looked quickly a couple of months back, no joy…
Ditto here & shipping is even worse! =$69
2 better value options - gasket & hole plugs but no base plate glands etc.
Good searching but DHL is not my friend with these prices.
