found this… but what is it ??
I’m pretty sure its a temp gauge for kilns, ceramic kilns. the “CONE” label is to mark the start of the transition of glazes that are applied to ceramics and the state of the clay, I think the smaller numbers in that area would be for different temp pyrometric cones … same type my parents used for their kilns, until dad got sick of reading it and swapped it to a digital rs232 temp monitor to talk to our atari st.
Tempature (pyrometer) meter for a ceramic kiln
ok tnx…
it came from someone who used to collect and polish minerals/stones/cristals… thing like that
what ? $145.00 ? I struck gold !
for some rf experiments I want to remotely switch the node/device antenna’s
bought the chips last year… but now I found complete modules that I will use
cheap IP 67 waterproof outdoor node enclosure with mounting bracket
Hi @BoRRoZ, you really made me laugh with this one. I studiously read all your workbench and bargain postings and often follow the links and sometimes buy samples of the things to try out.
I want to buy one of these… but - for the first time that I can remember - there does not seem to be a link with the image!
Please can you post with a link. Big thanks from me for all your posts.
Hi Tim , I bought long time ago 3 pcs (2 by mistake) 698-2700 Mhz antennas , absolutely not usable for LoRa … but I can’t throw things away '…can be used in the future
but maybe someday…
I’ll make it a bit smaller (and control over I2C)
better use some rf shielding enclosure
I build it as an I2C module So I can use it in some other projects too… plug and play
POC test
huh ?
@BoRRoZ here did you purchase this housing?
have to search… but I remember they don’t sell anylonger last time I looked… that’s because @Jeff-UK bought them all ![]()
sometimes here
Both out of stock. Aerial.net allready for a long time.
Sorry! ![]()
- I only took a half dozen! Work well with the Pilot & re-housing Laird RG186’s
I bought them as smaller/compact options as alternate to usual EZ enclosure : Outdoor Enclosure, 1 Ethernet, 4 N-type holes » E-zy.net
(They look to be old (think maybe 1990’s Nortel? sourced from EZ) CATV break-out/repeater cases - nicely made…5x Cable glands or N-type vs 4 for the SOE01 )
actually I could do with a couple more so if anyone finds some please shout here!
I looked quickly a couple of months back, no joy…
