Is there a known SX1302 maintained hal?
I try to build two gateways. One with bobcat (it’s ready but with forked SX1302_hal to disable temperature reading.) and one with raspberry zero w with IC880 (still building).
I realized that the original library is abandoned. Some valid PR’s like Modern GPIO access, or temperature sensor as non fatal error are not accepted. I have seen some forks from brocaar and mulitech (again with disabled temperature sensor)
There is a fork that is actively maintained?
Basics Station works well with SX1302. I have a Heltec SX1302 SPI concentrator module on a Seeed studio hat working with a Pi Zero 2W.
Thanks, I also had the idea to try basic station, but I am not familiar with it.
Hi, I am in the process off updating all my UDP gateways to Basics Station. For the base install procedure I am using the procedure as outlined at in LoRaWAN: Installing Basic Station and connecting to The Things Network V3 Stack – Beyondlogic I have had to make a few alterations, as this how-to was created in 2021 for 32 bit Raspberry Pi and I wanted do the install on RasPi 64 bit so to facilitate this edit the following file :-
/home/pi/basicstation/setup.gmk and change the following:-
ARCH.corecell = arm-linux-gnueabihf
ARCH.rpi = arm-linux-gnueabihf
to
ARCH.corecell = aarch64-linux-gnu
ARCH.rpi = aarch64-linux-gnu
If you are using a Corecell SX1302/SX1303 based concentrator (RAK5146, RAK2287 etc) build with platform=corecell:
make platform=corecell variant=std
Before starting station The SX1301/SX1302/SX1303 Digital Baseband chip should be reset after power-up, as “gpioset --mode=time” is no longer available I created the following script:-
Create a file called reset_gw.sh
And populate with:-
#!/bin/sh
SX1302_RESET_PIN=25
gpioset -t0 -c gpiochip0 $SX1301_RESET_PIN=0
sleep 0.05
gpioset -t0 -c gpiochip0 $SX1301_RESET_PIN=1
sleep 0.05
sleep 0.05
And make the script an executable:
chmod 755 reset_gw.sh
Also on the above site is a patch for the temperature sensor error
I am wondering if it’s a good idea to read the temperature from SoC and compensate for the emperature of concentrator.
