IMPORTANT BEFORE POSTING:
- Check the Learn section: https://www.thethingsnetwork.org/docs/lorawan/
- Check the Stack documentation: https://www.thethingsindustries.com/docs/
- Make sure you’ve searched the forum: https://www.thethingsnetwork.org/forum/search
- Check the vendor’s documentation
Summary
Hi…I’m back. I’ve been on/off trying to get images/video from the middle of a forest for years. I started here with sensors 2022-2023, went off and tried 2.4Ghz WiFi, Wifi HaLow, SDR etc and only 2.4Ghz WiFi worked but is a PITA. Anyway, FYI EU HaLow doesn’t work (non hobbled HaLow does) and SDR needs a Ham licence to transmit. I’m back with a LoRa PLUS Eval kit I just boughht and have dragged my “sunburnt” Dragino gateway out the cupboard. My goal is to sent images ESP32CAM > LoRa PLUS > Gateway > TTN LoRaWAN > webhook to my server. Question: Is this going to give you hassle or problems?
Logs
None
